Ir para o conteúdo principal
Uma furadeira/parafusadeira compacta de 18 V com íons de lítio e 2 velocidades fabricada pela RIDGID no ano de 2015.
How do I remove the chuck for replacement
I have removed the Phillips head screw, but all the instruction I find online, call for a torx head screw once the phillips head screw is removed. My model does not have that. is the chuck screwed on with internal threads or is it a press fit? Any help would be appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You’ll want to open the chick all the way so you can see inside it. Once that’s done you can see what type of driver you need my dewalt uses Allen key. Now here’s the important part the threads are reversed turn right to loosen the chuck. And no you can’t use the drills own power to do that. You need to hold the base while you turn it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mike será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 139
