Ir para o conteúdo principal
Informações de reparo, desmontagem e resolução de problemas do Motorola Razr (2024), um smartphone da Motorola lançado em 2024.
How to I replace exterior screen
how do i replace my phones exterior screen
Esta é uma boa pergunta?
Pontuação 2
1 comentário
What company do I order from that has the framework lines of perfect
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
Sorry to say iFixit doesn't have any guides for that repair on your phone, but the good news is they do have the factory service manual that tells you exactly how to replace the exterior screen, or CLI Display Module as they call it.
Motorola Razr (2024) Level 2 Service Manual - iFixit
Skip forward to Page 19 (it comes up as Page 27 on the document reader), where you'll find instructions for removing the screen. It's pretty basic; heat the adhesive then use a suction cup to create a gap. Insert an opening pick and slice the adhesive on three sides. Afterward, there are two screws holding down a bracket you remove to disconnect the display's flex cable.
As you work, take lots of pictures and once you're done you can use them to create your own iFixit guide to that repair. It's easy, fun and will earn the appreciation of the repair community.
Create a new Guide - iFixit
Esta resposta foi útil?
Pontuação 2
You hold down
Pontuação 1
Adicionar a sua resposta
Christy Dillard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 30
Últimos 30 dias: 127
Ao todo: 1,204
