Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone 14 Pro Max. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 14 Pro Max.
Why is my screen flickering after recent update?
Screen Flickers every time while closing apps
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If your iPhone 14 Pro screen is flickering after a recent update, ******it’s most likely due to a software glitch related to the update, but there are a few other possible causes too. Here’s a clear breakdown of why this happens and what you can do about it:
  1. Software bugs from the update;
  2. Display features interacting strangely with the new software;
  3. Incompatible or unoptimized apps;
  4. System background processes;
  5. Rare hardware triggers
Things that usually fix it:
  1. Restart the phone (sounds basic, but it helps more than you’d think).
  2. Check for another iOS update — Apple often releases quick bug-fix updates.
  3. Go to Settings → Display & Brightness and try turning True Tone off.
  4. Go to Settings → Accessibility → Display & Text Size and turn Auto-Brightness off.
  5. If it happens only in certain apps, update or delete those apps.
When to worry:
  • The flicker is constant, even on the lock screen
  • You see lines, green flashes, or blackouts
  • It started after a drop, water exposure, or screen replacement
In those cases, it could be a hardware issue and worth having Apple check it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Araf será eternamente grato(a).
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 31
Últimos 30 dias: 185
Ao todo: 996
