Ir para o conteúdo principal
Versão atualizada do MacBook Retina de 2016. Modelo A1534, EMC 3099. Agora equipado com processadores Kaby Lake mais rápidos, até Core i7 de 1,4 GHz com Turbo Boost de até 3,6 GHz e SSD até 50 % mais rápido, além de suportar até o dobro da memória.
removing back cover to replace battery
My Macbook air only has 8 screws - all of the videos show 10 screws.
I have removed all of the screws and go to remove the back and it does not lift off so nice and easy - looks like there is a catch about halfway on both right and left side. Do I force it open?
Update (01/22/26)
Okay - so first of all it was not a Macbook Air - it was a Macbook. I took a picture of the writing on the back and was able to zoom in and find the model and EMC number.
Once you get the screws out there are 2 clips - one on each side that are a bit stubborn...but you get them unclipped and you got it.
I also had the wrong battery....so wait for now
Thanks for the feedback
Pat
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hello, can you double check the model of MacBook that you have? Some of the older models pre 2020 have 10 screws. Try to find a model number/year if you can.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Pbmacsodak será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 181
