Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
Discdrive Works only on wiggle
CUH-1216A. Disc only reads on wiggle. See video:
https://www.reddit.com/r/consolerepair/c...
Can any of you help me out?
Disc drive refuses to read disk, only when wiggling then it wants to read it. Tried cleaning delaysia and try to cleaning the rubber where the disk is seated on. I am not very sure what happens or why it happens. It might be that it has not been clean enough. Do any of you have advice since AI is letting me down. It fries four time to read it or makes like a noise four times. Then tries to reset the disk. Then tries to read again four times.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Well, you have tried a lot already. I would replace the laser deck and see what happens. I think this will be most likely the solution.
There is no specific guide for that. You can follow this: PlayStation 4 Optical Drive Replacement
If you need a more specific guide, please let me know!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Fabian Stappers será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 17
Ao todo: 17
