Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para o mouse sem fio portátil Logitech MX Anywhere 3S. Lançado em dezembro de 2023 e identificado pelos números de peça 910-006925, 910-006926, 910-006927 ou 910-006928, dependendo da cor. Sucessor do MX Anywhere 3.
Left button not working
The left button intermittently works and has been getting progressively worse over time. Should I follow the disassembly steps as described to replace the battery and try and clean the buttons with compressed air?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @mcfb, if the Logitech MX Anywhere 3S is still under warranty, I recommend sending it in for repair. Based on my experience, once the warranty has expired the usual fix is replacing the microswitch. The part commonly used is an Omron D2FC-F-7N or similar, which requires desoldering the old switch and soldering in the new one.
Esta resposta foi útil?
Pontuação 3
4 comentários:
Thanks @augustine, I'm chasing warranty - I'll see how that goes first. Thanks for the help.
por Compartilhar
Is this a common problem with this model?
por Compartilhar
I have the same problem with left click, i'm going to try to repair the button. (Tape was not the issue, it was 100% the button malfunctioning)
por Compartilhar
This can't be true, those switches are substantially larger than the ones present in the MX Anywhere 3S
por Compartilhar
Adicionar a sua resposta
mcfb será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 39
Últimos 30 dias: 185
Ao todo: 1,293
