Adaptive Trigger Auto Trigger
I was just finished installing the Hall effect on the controller, and they work fine. However, the trigger motor for adaptive triggers on R2 activates on its own. I disconnected the flex cable, but it still triggers. It doesn't seem to be the springs or anything as the triggers work and they retract, just that the triggers just activate to like a resisting gun trigger every 4-ish seconds. Its seems to be software-related. An y Fixes other than disconnecting the wires?
Esta é uma boa pergunta?
Hi!
What does gamepad tester says? Also that it's pressed in? Is the firmware up to date? How are the traces? Are none of them are damaged during soldering?
Thanks!
por koppie007 Compartilhar
The traces are fine now the auto clicking stopped but when I use the https://ds.daidr.me/ Dualsense Tester the Triggers only go into resistance. The auto trigger mode does the same thing as resistance. The Only trace that was accidently torn isnt even related to that. Im fine without the adaptive triggers but my mute button doesnt work
por Elvin Eve Compartilhar
gamepad tester says normal, btw
Its not pressing in on its own, its just the adaptive triggers. Firmware is latest
Hmm, can you share some pictures with us regarding the motherboard and it's traces? Then we can take a look at it! Hopefully that is OK :)!
Thanks!
