Ir para o conteúdo principal
Lançado em 21 de setembro de 2018. Modelos: A1921, A2101, A2102 e A2104 / Disponível como GSM ou CDMA / eSIM ou nano-SIM / 64, 256 ou 512 GB / Prateado, Dourado ou Cinza Espacial (Pronuncia-se "iPhone 10 S Max").
Battery Behaving Very Strangely
I recently charged my iPhone XS Max (had its battery swapped out a year ago) and it just remained stuck at the dead battery icon no matter how long it charged. So I swapped the battery with the original battery I kept after having replaced it. The phone then turned on but won’t charge beyond 1% with the battery health not showing and the phone dying soon after. How do I fix this? all help would be appreciated!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It sounds like the battery isn’t communicating properly with the system, which is why it won’t charge past 1% and the phone dies quickly. Before trying replacements or repairs, it’s a good idea to run a full battery analysis. That can reveal whether the battery itself is failing, if there are faulty cells, or if the system is limiting charging due to power or sensor issues, giving a clearer picture of what needs to be fixed.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Hey there, I tried messing with the pjone for a bit and realized that the battery connection isnt fully seated so it causes the percentage to not read unless extra force is put on the connecter. I have found a *temporary* fix with some tape (between the cable and the metal shield that goes over it) to push the connector down.
por
Adicionar a sua resposta
TechVid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 15
Ao todo: 135
