Ir para o conteúdo principal
O celular vem com uma tela sensível ao toque de 6,50 polegadas, com resolução de 720x1600 pixels, densidade de pixels de 269 pixels por polegada (ppi) e proporção de 20:9. O Oppo A53 2020 é equipado com um processador octa-core Qualcomm Snapdragon 460 de 1,8 GHz. Ele vem com 4 GB de memória RAM.
Sim card not working
I bought a used phone online and the sim card doesn't work. What can I do?
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
Have you tried placing a new SIM? You may have to go to a carrier to buy a new SIM card.
Please specify whether the SIM slot has a SIM card or not. :)
por Compartilhar
@bryan56776
There are two sim card slots. None works. I have also tried a different card
por Compartilhar
@perivarmoen This could be an issue with the SIM card slot reader. I'm going to try and find the location of the SIM reader.
Have you tried doing a hard reset to your phone?
por Compartilhar
I did the factory setting
por Compartilhar
Adicionar um comentário
1 resposta
Does it show "No Sim" even with the sim card inserted? If so the sim reader in the phone might be damaged. Sometimes it can just require bending the pins because they are not making contact with the sim card. Other times it will require replacing the sim reader if the pins are actually snapped. It could also be caused by other issues like the phone being blacklisted or a more serious issue on the motherboard.
Esta resposta foi útil?
Pontuação 0
2 comentários:
It says "no sim"
por Compartilhar
See if you can look inside where you insert the sim card for any damage. Could also be an issue with the sim tray.
por Compartilhar
Adicionar a sua resposta
Per Ivar Moen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 14
Ao todo: 171
