Ir para o conteúdo principal
O Acer Nitro 5 AN515-58 é o lançamento de 2022 da série Acer Nitro 5. Este guia deve ser compatível com todas as variantes do Acer Nitro 5 AN515-58.
My Bios Setup Password
I want to access my BIOS Setup but before accessing it it requires me to input the BIOS password but I didn't even setup anything in the BIOS but before I install an Operating System where I purchase my laptop and maybe I think that they are the one that set it up. My Questions is what are the possible BIOS default passwords that technician input? the blank password is incorrect.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
We (general) IT technicians do not have a fancy list of all default passwords for all different systems, sorry.
When it comes to using a default password, removing the cmos battery, shorting a certain jumper pins and similar is stuff that was sometimes implemented in the past, but neither of these tends to even exist on a modern laptop in order to enhance security.
The boring answer is to ask your laptop retailer, and otherwise contact Acer support.
Reading from forums this issue seems to not be too uncommon with people (unknowingly) having a BIOS password on Acer laptops. Here's one Reddit example, some people mention that some of the default passwords works, a lot report that it does not. You can always try if you really want.
But my only recommendation in your case (especially as this is a newer laptop) is to go to your laptop retailer and asking about this. If they can't help you, then you should contact Acer support.
Hope this helps.
Cheers
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Gen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 48
Ao todo: 388
