Ir para o conteúdo principal
Os AirPods Pro 2 com um estojo de recarga USB-C possuem melhor proteção contra poeira, recursos de carregamento mais rápidos e a capacidade de usar Áudio Lossless com o Apple Vision Pro. Eles também contam com Áudio Adaptativo, Reconhecimento de Conversa e Volume Personalizado.
Left side is not working
My airpod got on water and i clean and drain it and it work for a weak but now the left side is not working what shaĺl i do
Esta é uma boa pergunta?
Pontuação 1
1 comentário
It fell down only
por
Adicionar um comentário
7 respostas
Pergunta mais útil
Unfortunately, there is not much that you can do, AirPods are generally impossible to open and repair without causing damage to the plastic case.
Water damage happens when corrosion from minerals from your water make contact with the circuit boards of your earphones. You may have to throw away your left earphone since the damage has already happened. Sorry for your situation :(
Esta resposta foi útil?
Pontuação 2
Well I will suggest you to checkout the following video: https://www.youtube.com/watch?v=Z77mEmP1...
Pontuação 0
Some time only I used both AirPods but most of time I used only one side AirPods. One day when I used both AirPods that time I realised one of them AirPods it’s not working.
Pontuação 0
I have the same problem only my left ear pod is not working also I didn't drop in water
It was kept on a computer desk and will use it once a week, I tried cleaning the ends and charge ends but nothing works, the right side works and charges asusual
Pontuação 0
No
It fell down only
Pontuação 0
It fell down
Pontuação 0
Lift side no working
Pontuação 0
Adicionar a sua resposta
saba beyene será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 77
Ao todo: 654
