Charging USB is broken
Esta é uma boa pergunta?
Hi!
If it’s broken inside (like pins that are bent), you need to replace the port.
Replacing this one is NOT easy. You need to solder and need soldering skills to get it fixed!
Guide: Substituição da porta de carregamento do controle PS3 Dual Shock 3
Please let us know how it goes!
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 16
Ao todo: 368
1 comentário
Could you disassemble it and check if there is continuity with a multimeter? Maybe it's just a solder joint that broke
por dinoo_fixit
