How to fix starter disabled mode
How do. I fix my 1998 Deville it says STARTER DISABLED on dash
I've disconnected battery,for days now help
Esta é uma boa pergunta?
From a post on justanswer.com, they have several suggestions you can try.
1998 Cadillac DeVille Starter Disabled - No Clicks, No Sound - Expert Q&A
Here's the relevant section:
== 1998 Cadillac DeVille Starter Disabled No Clicks No Sound ==
DeVille owners often face starter relay failures and ignition switch malfunctions causing no-start conditions.
A 'starter disabled' message with no clicks or sound often points to a faulty starter relay or ignition switch issue. First, check the starter relay in the fuse box for continuity and replace if defective. Inspect the ignition switch for wear or electrical faults, as it controls starter engagement. Also, verify neutral safety switch operation if automatic transmission is present. Ensuring battery terminals are clean and connections tight helps rule out power delivery problems. Addressing these components typically resolves the no-start condition without clicks or sounds.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 39
Ao todo: 185
