My laptop isn't displaying an image, only the battery light is on. Wha
My laptop isn't displaying an image, only the battery light is on. What could be the problem?
Update (12/29/25)
dell xps l502xdell xps l502x
Esta é uma boa pergunta?
Hi @juniosilva
Try a full power refresh and check if this resolves the problem.
Here's the service manual that will help. Go to p.37 to view the procedure to remove the coin cell battery.
When the coin cell battery is out measure its voltage. If it is <2.5V DC or if the battery is >4-5 years old replace it. The battery model number is stamped on the battery. Not sure if it is a CR2025 or a CR2032 but these are readily available most everywhere e.g. supermarkets.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 76
2 comentários
This question was migrated from https://meta.ifixit.com/Answers.
por iRobot
I assume it's plugged in? The battery light being on when plugged in just means it's charging.
Not displaying an image could be many things. Is it also not playing audio, not spinning fans, and not making any other noises? Or is it just the display?
por fleetinbeing
