Set Rinse Cycle as Favorite
I have a new Bosch SHP65CM5N/27 dishwasher with the control panel on the top of the door. There is no Rinse cycle available in the cycle choices on the control panel.
There is a rinse cycle available in the Home Connect app. But the Update Favorite link in the app to store a selected cycle as the favorite on the machine is not displayed when I select the Rinse cycle in the app.
This means that so far the only way to run a rinse cycle is using the app. Is there a way to set the favorite on the machine to Rinse?
If not, is there a way to tailor one of the cycles on the control panel, like the Speed60 cycle to run for a short period like 10 minutes to do a rinse?
So far my "solution" has been to start a Speed60 cycle and then manually turn the machine off after 10 minutes or so.
Thanks for your help.
It seems almost unbelieveable that anyone would make a dishwasher that does not allow you to rinse without using your phone. Stupid.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
