How would I add more RAM?
I have this laptop and would like to add more RAM to it but don't want to damage my laptop, how do I add extra RAM if possible?
Esta é uma boa pergunta?
Hi!
Unfortunately that is not possible. The RAM is soldered on the motherboard. Unless you have some serious soldering skills.
The SSD and WiFi are replaceable tho.
Guide: 🛠️ Lenovo ThinkPad L13 Gen 2 - disassembly and upgrade options
Please let me know if you have any further questions!
Esta resposta foi útil?
I have the Lenovo ThinkPad 13 gen 2 20J2. I have disassembled it many times and have come to learn that it has 2 SODIMM memory slots that can be seen when removing the bottom cover. I'm not sure if every model or variation has modular memory, but mine does.
Hi!
Usually this is not the case for this model. Can you share some pictures with us? Also regarding the motherboard model?
Thank you!
Últimas 24 horas: 6
Últimos 7 dias: 20
Últimos 30 dias: 87
Ao todo: 719
1 comentário
It might be better if you consult in a professional to fix your problem. The cost might be low because of quick work. It will likely take 10 minutes to finish
por Desoloc, Rysus Roel Compartilhar
