How do I replace the leather headband?
So I want to replace the leather headband on it, but it looks like I have to open it up but I don't know how to. Any help will do thank!
Esta é uma boa pergunta?
This model has screws holding down the headband, you can loosen these a bit and then pull the ends of the headband out.
You will also need to slice open the old headband along one seam to get it off - I'm working on a guide for this. You can sew your own replacement band, or search up 'ATH-M20x headband replacement' etc. to buy one online.
Some of the replacement headbands I saw online seem to zipper on straight over the top of the old headband.
Esta resposta foi útil?
Hi Dulfo!
I checked some of the similar models (that had pictures), and most models seem to have screws holding down the clamping mechanism for the headband. See the following image:
(Original Image courtesy of Broske in their Desmontagem do Audio-Technica ATH-M50x, my modifications)
I cannot say exactly how the headband is taken on or off, but hope this lead helps! Otherwise I'll hope that that teardown may be useful.
Cheers!
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 65
Ao todo: 483
