Ir para o conteúdo principal
Lançado em 28 de julho de 2017, o New Nintendo 2DS XL é um remodelamento tecnologicamente aprimorado do portátil 2DS. É o nono e último redesenho da linha Nintendo DS. O console é muito maior que o modelo 2DS original e adiciona todos os recursos da linha atualizada de sistemas "New 3DS", menos a capacidade de reproduzir jogos em 3D estereoscópico na tela superior.
problems with hinge/spine of 2ds?
so when i try to move the top screen of my new 2ds backwards after repairing and swapping the shell it doesnt close fully on the back and has trouble when i try to put the top screen flat in line with the bottom ive tried opening and cleaning it i also reseated the top lcd
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This usually happens when the hinge isn’t aligned correctly after the shell swap. Even if the screen and LCD are re-seated, the top housing won’t close or sit flat if:
1. The hinge barrel isn’t fully rotated into its locked position.
It needs to “click” into place. If it’s off even a little, the lid will resist closing.
2. The ribbon cable has tension or is twisting inside the hinge tunnel.
A slight twist is enough to keep the top shell from lining up.
3. One of the hinge tabs isn’t sitting in the shell track.
The system will close on one side but not the other.
Quick fix:
Open the system back up, rotate the hinge fully until it locks, check that the ribbon sits smoothly with no sharp bends, and then reassemble.
No new parts needed unless the hinge barrel is cracked.
If you want, I can tell you exactly how to check alignment step-by-step.
Esta resposta foi útil?
Pontuação 0
1 comentário:
that would be nice thanks
por
Adicionar a sua resposta
God o será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 57
Ao todo: 540
