Ir para o conteúdo principal
Lançado em julho de 2018, o MacBook Pro de 15", modelo A1990, possui uma tela de 15,4 polegadas com retroiluminação LED e tecnologia True Tone, TouchID e processador Core i9 de até 6 núcleos.
Topcase Replacement Issues - Wont display
Hi all,
I had to replace my top case on my 2018 MacBook Pro 15 inch (A1990). I worked through everything slowly and purposefully. When I tried to turn it on it wouldnt turn on. Then I connected the mains power adaptor and it fired up, I heard the chime but nothing on the display. The Touch Bar lit up and I could increase the volume and decrease but nothing else. Now I cant turn the unit off.
Can anyone shed any light on what might have gone wrong with the procedure or what I need to do to get it up and running again!
Many thanks
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
Why did you replace the top case? Do you mean the display lid part or the uppercase keyboard part?
por
It was the keyboard part DanJ
por
@mansoorahm23124 - OK, did you have a liquid spill of some sort?
por
No, some of the keys were missing so thought of replacing the keyboard. Unfortuantely, that meant replacing the topcase in its entirety!
por
Adicionar um comentário
1 resposta
I would look at the guides and check that the LCD cable is connected and also the battery connection. IF still no improvement then prehaps @danj can give some more insight.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mansoor Ahmed será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 186
