Ir para o conteúdo principal
A Nikon D3X é uma câmera reflex digital de lente única (DSLR) profissional full-frame de 24,4 megapixels lançada pela Nikon Corporation em dezembro de 2008.
Clock battery on D3x
I recently bought a second hand D3x, Im very happy with it. I read somewhere (?) that I may need to replace my clock battery. This makes sense to me as every time I take the battery out to recharge, it resets to 2007 and resets the counter. Where is the clock battery on this camera and is it something I can replace myself?
If I recall correctly they gave a battery type in the article, which I sensibly didn't write down.
I trust you can assist me with my current quest. Thank you in advance for being here in the first place.
Bebb
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Is this what you are looking for? Replacing D3 Camera Clock battery
Esta resposta foi útil?
Pontuação 1
1 comentário:
The clock battery is located in the roof of the main camera battery compartment, concealed by a slide out cover. Its easy to locate and the battery in question you require is a CR1616 - 3 volt battery which are readily available.
I find they last a long time having only replaced them very occasionally on both the D3 and D3X
por
The Clock battery is a 1616 cell battery. It is found by removing the main battery and looking to the top of the battery chamber, here you will see a sliding cover which if you slide out of the chamber will reveal the battery. Nice simple one when you know
Pontuação 0
Adicionar a sua resposta
david bebb será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 25
Ao todo: 174
