Ir para o conteúdo principal
Guias de reparo e informações de desmontagem para o MacBook Pro de 16" lançado em novembro de 2019. Modelo A2141, EMC 3347.
Stuck in DFU mode
Laptop had water damage on elc180 that powers nand chips, after repair laptop is stuck in DFU mode and revive option gives error amrestoreerrordomain – 0x6 (6)
Data is the most important part of the repair if i do a restore and delete data from laptop repair is not of anny help.
does someone have a solution that saves data.
All voltages and resistances are fine laptop is only not turning on vcore on cpu and gpu.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The low level aspects of the Flash chips (NAND) are corrupted. Without a DFU restore you really can't get past to save the data, sorry.
As a Hail Mary see if an external drive which is setup as a bootable drive will at least let you boot up. While you likely won't see the internal drives data as it's encrypted by the user account can you even get that far?
Esta resposta foi útil?
Pontuação 0
2 comentários:
Hi, do you by anny chance have T2 rom files for A2141 820-01700-05
por
@dimitrijes46692 - The T2 chip is not reprogrammable! It is a gate array chip with a burnable Readable only ROM. The systems firmware is held in a EROM chip, but that won't help you here. That nukes the access to the NAND's like rebuilding via DFU.
por
Adicionar a sua resposta
Dimitrije Stefanovic será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 33
Ao todo: 552
