Ir para o conteúdo principal
Keyboard light stopped working
I need to know how to get my keyboards key lights to start working again. I believe its in the physical functionality itself as ive checked all software and settings.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
This may differ from one Lenovo model to another.
In my case, Keyboard backlight can be changed in the Lenovo Vantage application. In Device Settings > Input > Keyboard backlight brightness. There I can change between low, high and off in terms of brightness level.
The hotkey combination in my case is FN + space to change between the different brightness modes.
Hope this helps,
Cheers
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for responding. However, I received more information on what happened when the keyboard backlight stopped working. One of my teen aged boys admitted to dropping something heavy on the keyboard. I suspect the problem is more of a physical nature at this point. Thank you for your response, though
por
Adicionar a sua resposta
DannyBoy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 39
Ao todo: 317
