Ir para o conteúdo principal
Lançado em janeiro de 2023 com processadores Intel série H de 13ª geração e disponível com uma RTX 3050 de 4 GB. Possui um chassi de alumínio e magnésio, uma tela OLED de 14,5" com resolução de 2880x1800 e é identificado pelo número de modelo UX3404.
Flickering screen repair steps
The screen of the laptop is flickering. I was recommended to change the screen. Is it repairable
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
who recommended replacing screen? The flickering can be caused by many problems. Screen replacement would be the last option.
First open a CMD prompt window and run chkdsk c:
Then open a CMD prompt window as admin and run scf /scannow
Then look for the lasted driver for your video system and install that.
Now, if you have a video port on the laptop, try connecting an external monitor. If that doesn't work, it is likely a problem on the MB.
If you got this far without solving the problem and the external monitor worked, open the laptop and disconnect and reconnect the screen cables - search for how to open the connectors and be careful as the are fragile.
If the problem still exists, now you can consider if it is economically feasible to replace the screen or buy a new computer.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Micro center’s repair tech recommended replacing the screen. I have tried your suggestion, the problem persist but the computer works with an external screen.
por
Adicionar a sua resposta
Babacar Faye será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 41
Ao todo: 465
