Door switch configuration - Donga switches marking
Hello, I have a GE Profile Microwave, PEB 9159SJ2SS. Turntable and light continued to run when door open (but obviously not heating - no loud hum). Ran this way for several months. Now unit not heating. I'm buying a new one but for fun pulled the switches out to examine. Three DONGA switches. 2- prong. First question is the labeling on the switches ALL show a wire/conduit COM-NC, but when I test them the top 2 (primary and monitor I think) were NC but the bottom latch (secondary?) was NO. It did not show continuity until I pressed the button. I opened the switches and the internal structure matched my multimeter finding. Also, the terminal on the NO switch (lowest one in the plastic frame) was physically lower on the case of the switch and abeam the NO label, but again the stamped label showed same as the others COM-NC. Is this normal? that the labels don't match the internal setup? and more importantly, when I look at the official parts list/diagram on GE's website, the MIDDLE switch shows different. Everything on YouTube says the middle (monitor) switch is different. Now, I did find some arcing and damage in the top switch - perhaps this switch is SUPPOSED to be NO and it damaged itself so it tests NC and I got confused by the labeling (which perhaps is meaningless). Anybody know how this model is supposed to be configured?? recap, my config now seems, from top to bottom, NC, NC, NO. If the to switch should be NO but it failed to NC, would that cause the turntable to continue rotating with door open? in this case, the fail safe would still work. Thanks SO much in advance for you guru's out there!. Scott
Esta é uma boa pergunta?
