Ir para o conteúdo principal
How to fix my wire sensor
can please guide me on how to replace the sensor that activates the earbuds on and off
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It sounds like your wire sensor issue is likely caused by a loose connection or internal break, which is pretty common over time. Starting with a careful visual check for damaged spots or bent pins can save you a lot of guesswork. If everything looks fine, testing continuity with a simple multimeter usually helps pinpoint the fault. I’ve had similar problems while working on small device repairs for mesolyft.com projects, and a clean reconnection or replacing the damaged segment often did the trick. If none of that works, the sensor itself may just need replacing.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Prince Chaba será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 191
