Ir para o conteúdo principal
Headphone gamer com fio Redgear Cosmo 7.1 USB, over-ear, com microfone, som surround virtual, driver de 50 mm, LEDs RGB e controle remoto (preto)
Fixing broken head sets
My headset is not working I am not actually interested with the mic I'm mostly interested with the speakers. I need instructions on how to connect the wires from the in line control pod directly to the speakers
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Based on your post I take it that your headset cable is broken.
If the cable is broken by the headset, you may be able to get away with just shortening the cable, and re-soldering it inside the headset. Tho, make sure to take pictures and notes of which wire goes where. The wires used in headsets are usually very tiny and can be a bit tricky to solder.
Otherwise, you will have to open your headset and the controller pod, and note which cable goes where. Then you can de-solder the broken cable and solder on a new cable. Though, the solder pads on the circuit board can be a bit tricky to solder.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Martin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 44
Ao todo: 337
