Ir para o conteúdo principal
Informações de reparo, desmontagem e resolução de problemas para o Steam Deck OLED, uma atualização de 2023 do popular console de jogos portátil fabricado pela Valve. Lançado em 16 de novembro de 2023. Identificado pelo número de modelo 1030.
Steam deck Battery Health
When I got my Steam deck about a year ago, I would get 8-9 hours in half life 2 and 2.5 hours in cyberpunk 2077, now I get around 6.5-7 hours in half life 2, and 2 hours in cyberpunk, should I replace my battery soon, or wait a bit to replace it, the system still says its at 100% percent health but I don't believe that number entirely.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
could be dried thermal paste causing the CPU temperature to rise and requiring higher fan rpm to cool the console, drawing more power and decreasing battery life. Does your Steam deck feel hot when gaming?
por Compartilhar
Not really, if sits around 65-70 degrees when playing a really heavy game like cyberpunk
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
You probably shouldn't replace your battery right now. All battery age, but if there's only about an hour's difference in battery life compared to when it's new, replacing the battery now would be a waste. A new battery's both expensive and pretty hard to replace if it's your first time fixing stuff. If it works, it works. Wait until the battery life's significantly short or when it starts to bother you a lot, then replace it.
However, if you're really paranoid about battery life or feel like you'd like a few more minutes of cyberpunk, here's the guide.
Steam Deck OLED Battery Replacement
A lot of glue and fragile cables, so make sure you follow the steps carefully. It would be a good idea to read the guide before you actually start to replace it, to get a general idea of the steps.
Esta resposta foi útil?
Pontuação 0
1 comentário:
That's what I thought as well, I've repaired adhesive batteries before, but I agree that I should probably wait to replace it.
por Compartilhar
Adicionar a sua resposta
Caleb será eternamente grato(a).
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 62
Últimos 30 dias: 257
Ao todo: 3,277
