Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
LCD panel removable from the shell?
Do you know if the actual LCD panel is removable from the top case, or is it glued inside like the MacBook Air?
It seems to me like a hybrid between the heat-gun approach from the Unibody MacBook Pro and the don't-go-there-unless-it's-broken separation of LCD and backlight that comes from the Air. What do you think?
I'm gonna buy one tomorrow and will try to find out.. Any pointers on how to do so without ruining this hyper-expensive screen?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Nope, glued.
Also it includes a crapton of other stuff that's all right in with it.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Ps, how do you know about the crapton? :)
por
It's all in the teardown I linked in my answer.
por
Oof.. Did you succeed in removing it without breaking the LCD?
por
Adicionar a sua resposta
victormilton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 1,039
