Ir para o conteúdo principal
Guias de reparo e informações de desmontagem para o MacBook Pro de 16" lançado em novembro de 2019. Modelo A2141, EMC 3347.
PROBLEM with screen image.
Imagem
Today i had this surprise... the computer is working... if i connect a Hdmi to a tv or monitor.. it works fine.... has energy signal in the LCD but.. doesn´t appers any image in the Monitor ..is this a Flex or Tcon defect .. or i have to replace the intire Screen .. ???
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It's hard to tell just from the grainy picture. Is the screen lighting up (glowing) if it is the backlight is working so that would remove the backlight flex issue.
Does the screens image change in any way moving the lid up and down or connecting or disconnecting the HDMI connection? If not then I would say the T-CON has an issue or the connecting to it. This is a different cable than the LCD cables which compose the image within the LCD. Do you have any damage within the Chin plate which sits just below the displays image area? That would be the LCD cables being damaged.
And lastly you didn't have a liquid spill or place the system down on a wet surface as the back hing area is quite open and wouldn't take much to get into the T-CON board.
In any case the display assembly would likely need replacing MacBook Pro 16" (2019) Display Assembly and here's the guide Substituição da tela do MacBook Pro 16" 2019
Imagem de Replace a display compatible with a model A2141 2019 16" MacBook Pro laptop. Includes the 3072 x 1920 LCD screen, display cover, bezel, FaceTime HD Camera, and clutch hinges.
Produto
$444.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
orlando reis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 74
