Ir para o conteúdo principal
Repair for moveable articles and décor for use in the house or office.
20 Perguntas Visualizar todos
How can I completely refurbish this old chair?
I have a place where I can get the chair reupholstered. However the upholsterer wants the wooden legs and arms and wings refinished first.
Should I just go to a local carpenter or sand them out and refinish them myself considering they are kind of intricate?
Do I need to take it apart first or will this make it harder on the upholsterer to complete her job?
Anyone with experience to share on this would help.
Thanks
Frank
Esta é uma boa pergunta?
Pontuação 4
4 comentários
Please post a photo so we are all on the same page ;-) Do you have an air brush capable of sand blasting?
por
Photos to follow. Stay tuned. I am too busy to get to it for another two weeks. Should have held off asking.
por
Show photos of your breakdown. it is impossible to say something definitely without seeing the situation itself.
por
Unfortunately, without a photo, it is definitely impossible to say anything. I can suggest you read the material about choosing Lounge Chair https://furnishingsmaster.com/best-outdo... . Perhaps this will push you to the parameters that should be taken into account when buying a good chair and will allow you to find something for yourself.
por
Adicionar um comentário
3 respostas
Solução escolhida
I love woodworking, but absolutely hate sanding unless it's the final pass. On antiques, you want to be especially careful with the sandpaper.
Since you haven't specified, I'll make an assumption that the legs are lacquered or varnished with a clear over some wood stain. If that's the case, these steps have always produced great results for me:
Get a small can of acetone and/or a small can of MEK. They both accomplish the same task, but the Acetone evaporates extremely fast, so is good for final cleanup. These chemicals are harsh on the eyes/skin, so wear proper protection. It's the same stuff used in paint remover, without the messy goo and extra $.
You'll also need a couple of green scotch-brite pads, some lint-free rags (old t-shirts), and an old toothbrush.
Dip the toothbrush in the MEK and start gently scrubbing on the wood. You will see the old finish dissolve quickly. Every so often, wipe of the dissolved finish with the towels and use the scotch-brite pads to get off any tough spots or larger flat areas.
Finish up with a final wash of MEK or Acetone. You will notice that the chemicals will also dissolve the stain a bit, which is terrific, since it ends up spreading around to even out any nicks, scratches, and faded spots.
Finish off with a coat of clear varnish, choosing the gloss level to your liking and send it off to the upholsterer.
Good luck!
P.S. Be sure to dispose of your old rags appropriately according to the label directions - spontaneous combustion from a closed garbage can in your garage would not be a pleasant experience.
Esta resposta foi útil?
Pontuação 4
If you can remove the legs then do it. sanding and varnishing wood is really easy it just takes time and makes a little mess =)
Pontuação 0
Given the right paint, why not?
Sand it really carefully... I saw people using sandblasters, but if you prefer doing it by hand you can use sandpaper of increasingly fine sandpaper, but never, ever using the coarse one.
A good tip I've read is labeling the joints, like in a puzzle, so you'll know how to put it back.
Of course, you're advised to sand and paint every piece separately.
Here's a good resource, by the way.
http://www.ronhazelton.com/projects/how_...
Pontuação 0
Adicionar a sua resposta
040304 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 1,547
