Ir para o conteúdo principal
Modelo A1419 / EMC 3070 / Meados de 2017 / Processador Kaby Lake Core i5 de 3,4, 3,5 ou 3,8 GHz ou Core i7 de 4,2 GHz (ID iMac18,3) / Tela Retina 5K. Consulte os guias do iMac Intel 27" com tela Retina 5K (final de 2014 e 2015) mais antigos, pois o sistema é muito semelhante.
OEM hard drive replacement
What is the Kit for an OEM hard drive replacement
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Is this what you are looking for? SATA HDD to SSD upgrade or PCIe/NVMe Blade SSD upgrade
And here's the two guides:
The HDD drive swap-out is the easiest to do, but the Blade SSD offers better performance.
Do keep in mind if you have a Fusion Drive you have both drives present! And you will need to disable the Fusion Caching SSD (Blade Drive) otherwise you'll encounter issues as it wants to join the fun which you don't want!
The easiest way to disable it is once you have the system running open Disk Utility and make sure you select show all volumes so the hidden Cache drive can be selected and reformat it deleting it fully. Is mostly a useless drive as it's too small to effectively hold the OS.
Imagem de Upgrade the storage and improve boot time and read/write speed in your iMac Intel 27" Late 2012-2019 with this SSD upgrade kit.
Produto
iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
$146.99
Imagem de Upgrade your iMac with a new SSD to dramatically speed up your machine.
Produto
iMac Intel 27" (Mid 2017-2019) SSD Blade Upgrade Bundle
$249.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Core Solutions será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 122
