Ir para o conteúdo principal
Guias de reparo e informações de desmontagem para o MacBook Pro de 14 polegadas lançado em janeiro de 2023, equipado com sistemas em chip (SoC) M2 Pro e M2 Max desenvolvidos pela Apple.
Battery replaced not working
I have a a2779 MacBook Pro , I started getting a service battery warning last week and when I run out of power the mag safe started flashing orange and did not charge , I ordered a replacement off I fix it for the model, I fitted it this morning and when I plug the mag safe in now with the new battery installed I get no light and it does seem to charge, I tried to charge via usb c left it charging for 1 hour but nothing, can anyone help? Thanks in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
A common issue is forgetting to set the ZIF latch from the Battery board or the cable./connector is damaged. Review Step 7 ~ 9 Substituição da bateria do MacBook Pro 14" início de 2023 here is the referee making sure the latch is not set, sliding in squarely the ribbon cable and carefully setting the latch so it's grabbed. Also check the battery side connection as well.
If the cable is damaged you'll need a replacement MacBook Pro 14" BMU Flex Cable - Apple P/N 923-08652
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Joedee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 160
