Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Perguntas Visualizar todos
Touchscreen not responding HELP! do I need a new digitizer?
hello,
i have a 3g iPhone and i've broken the
glass of the iPhone..
it worked fine until i dropped it again..
everything works besides the touch itself
wont respond...
i am thinking of buying a new digitizer
will that make a difference?
or is it my logicboard...?
advices please ! thanks!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
4 respostas
Solução escolhida
Try rebooting it, if this doesn't fix it, then the digitizer is dead.
Esta resposta foi útil?
Pontuação 1
1 comentário:
so if i change my digitizer it should work??
por
You should try replacing it, its pretty easy only one important thing BE PATIENT, and take your time.
Pontuação 0
Am 90% sure that its dead and you need a new digitaizer but ckeck the 3 cabels under the LCD maybe it just unpluged after the drop.
Pontuação 0
i have an iphone 3g and my touch screen doesnt work. i opened my iphone and i saw cable #2 has been ripped. i want to know if i really need to replace the digitizer. thx
Pontuação 0
1 comentário:
Adicionar a sua resposta
stephneim será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,756
