Why is there a 'Jumper' wire? For what purpose?
Continuing from this question (Solved) Charging issue (Fading Green Light Only)) I have noticed this jumper wire has been installed..... I cannot find any purpose under the schematics that I understand.... ??? Anyone know?
2017 A1466 13" MBA / Board # 820-00165
R6125 / R6120 (Mount type SMD Jumper to Pin > R6110)
Esta é uma boa pergunta?
3 comentários
@oldturkey03 It is sometimes charging the battery and sometimes giving the fading green or orange light and not charging.... temperamental.
Zenner Diode D7012 (Voltage Divider) was shot, and is now correctly charging the battery..... but, still getting a fan error in diagnostics & a thunderbolt hardware issue which we are still troubleshooting.
Replacing a burned USB Port
por livfe
@livfe sounds like your lines to the SMC are flaky. Don‘t forget to check those. It‘ll be a bit of a chase….nothing worse then intermittent failures. Best of luck and let us know how it works out.
por oldturkey03
@oldturkey03 Yeah that will be the last job to do after we fixed (IF possible) the thunderbolt port issue, maybe maybe if that gets fixed it makes a miracle!
por livfe
