Ir para o conteúdo principal
MacBook Pro Trackpad randomly clicking without me tapping.
MacBook Pro 2018 randomly clicking without me tapping, just hover around a page and its starts clicking randomly, opening the wrong links and pages. This happened after I replaced the battery.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Can you narrow down which model you have. Different series used different tech and parts! Go to About this Mac and tell us what is tells you size, year and model name
por
Well I will suggest you to checkout the following video: https://www.reddit.com/r/macbookpro/comm...
por
MacBook Pro A1989 model
por
Adicionar um comentário
1 resposta
This series uses a tapic engine which is dependent on a capacitance feedback of your finger. An oily trackpad can mess up the sensor and over doing the cleaning fluid can creep under the trackpad messing it up as well.
Using a clean micro fiber cloth spay a small amount of countertop cleaner onto the cloth (never the system) and wipe the trackpad surface. See if that helps.
If not, that aims us to a bad trackpad. Luckily it's one of the easier ones to replace! Here's the guide Substituição do Trackpad do MacBook Pro 13" com Touch Bar 2018 and here's the needed part MacBook Pro 13" (A1706, A1708, A1989, A2159) Trackpad
Imagem de Replace a scratched or malfunctioning trackpad compatible with a model A1706, A1708, A1989, or A2159 MacBook Pro 13" with Retina Display.
Produto
$29.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
George Elei será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 110
