Ir para o conteúdo principal
Guias de reparo e informações de desmontagem para o MacBook Pro de 16 polegadas lançado em novembro de 2023, equipado com SoCs M3 Pro e M3 Max.
Battery issues after screen replacement
I performed the screen replacement from the website. The good news is the new screen seems like it's working perfectly. The bad news is that the battery seems like it is not working at all. There is an X over the battery symbol and it says it's on AC power.
I'm afraid I may have damaged the battery connector reference in step 20 of the repair. It says to life the hinge no more than 45 degrees, but I missed that. I lifted the hinge probably slightly more than 90 degrees. Is it really that delicate? I guess it's also possible the battery data cable could be the issue. I dropped it on the floor while doing the repair and it got kind of dirty. My only other thought it maybe I didn't torque down the screw enough in step 19. Hoping to get anyone's thoughts. Thanks in advance!
Update (10/30/25)
Imagem
Imagem
Here are my connectors. I suppose they look somewhat loose to me, but I was afraid of pushing them in further for fear of bending the ribbon cable.
Update (10/30/25)
Imagem
Update after cleaning and reseating battery data cable. Looks like everything is working!
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Re-seat and clean the battery data cable.
Reset SMC.
If still “X”: replace the battery data cable.
If still no battery detected: logic board connector is damaged → board-level repair required.
por
@ben58240 - Can you take a few pictures of the battery connection as they are now as well as the battery data cable connections (both sides) Steps 15 ~19 and post them here so we can see what's happened.
por
@danj thanks for responding, I edited my original post with some pics.
por
Adicionar um comentário
1 resposta
Solução escolhida
@ben58240 - Your second image looks like the cable end is not square in the ZIF connector. Install this gem of an App CoconutBattery let's see what it tells us so we can check the battery power connector.
Esta resposta foi útil?
Pontuação 1
1 comentário:
@danj Thank you so much for the help! I cleaned and reseated the data cable and it looks like it's working! I edited the post with the output of Coconut Battery.
por
Adicionar a sua resposta
Ben será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 35
Ao todo: 316
