Ir para o conteúdo principal
Repair information, service guides, and troubleshooting help for refrigerators manufactured by Frigidaire.
Ice Maker Not Filling
Frigidaire Model LFSS2312TF4:
Ice Maker is not filling with water. Replaced water valve and confirmed water line not frozen/blocked. Ice Maker "on/off" lever moved back and forth. Fridge unplugged and replugged in to reset. No change.
What else could it be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @djs13512 ,
The ice maker water valve operation is controlled by the ice maker.
Here's the service data sheet for the refrigerator.
See the description (lower left side on p.1) for how to test the ice maker.
If the ice maker is faulty search online for 241642534 to find suppliers that suit you best.
There's also a wiring diagram that may help as well
Imagem de Replace a malfunctioning Ice Maker Assembly in select models of Electrolux refrigerators.
Produto
241642534 - Electrolux Refrigerator Ice Maker
$149.99
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
DJS será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 81
