Why is there no suction
There are no blockages, the filters are clean, the roller is turning. But there is no suction. It worked yesterday before I cleaned it. Now it is clean and it doesn't work
Esta é uma boa pergunta?
Hello @laney89560
The fact that it stopped working right after cleaning the canister could hint at something that happened during the process. I imagine you have done it several times and are very familiar with all the pieces that have to go back inside the vacuum after a cleaning but do you notice any gaskets / seals / rubber rings or parts that help create suction missing from the canister or around the canister area? Something that could have accidentally detached / unglued / snapped while emptying the canister?
Alternatively, do you notice anything that might have gotten stuck where all the parts along the vacuum snap / click together? Or any damaged / cracked plastic that allows air to enter the system at a place where it shouldn't?
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 243
