Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
PS3 Not turning on
When playing with my PS3, it just powered down, and then it flashed a flashing red light, then pressing the on button, it went green, then back to a flashing red light with nothing on the screen.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
It could be 2 things!
1: PS3 is overheated and so you need to remove the dust and replace the thermalpaste.
Always try that first!
2: APU issues! You can try the reflow first and see if that works! Most Of the time this fix is temporary… a reball will solve it, but is very difficult to do and you need special equipment.
Guide regarding the reflow: Yellow Light of Death Repair
Please let us know how it goes!
Esta resposta foi útil?
Pontuação 2
2 comentários:
A reball won't fix it, the issue is the connection between the die and the interposer. It needs to be replaced with a 65 or 40nm GPU for a true permanent fix. I recommend watching RIP Felix on YouTube if you want to explore this more.
por
It's a possibility that there are colt solder joints beneath the GPU. Reballing will fix the colt solder joints. If it's between the die and the interposer then indeed a reball won't fix it. Do you have a link for where Nihal can buy the GPU? Thanks in advance!
por
Adicionar a sua resposta
Nihal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 5
Ao todo: 52
