No boot device found
My Dell is unable to find a bootable device
Esta é uma boa pergunta?
Your problem means it can’t detect your hard drive or operating system. First, restart and enter the BIOS (press F2 or F12 at startup) to check if the hard drive is listed. If not, reset the drive or replace it. If it’s detected, ensure the boot mode (UEFI/Legacy) matches your OS installation. You can also run Dell Diagnostics (F12 menu) to check for hardware issues. If everything seems fine, use a Windows recovery USB to repair the boot files or reinstall Windows to restore proper startup functionality.
Esta resposta foi útil?
Well I will suggest you to checkout the following video: https://www.youtube.com/watch?v=LxxINiDD...
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Ao todo: 178
