Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para o iMac 24" da Apple com SoC M4, lançado em outubro de 2024.
The mouse no longer functions
The mouse no longer operates. I can see it, but it won’t move. I have restarted it and still nothing. The iMac is only six months old. I tried to connect another mouse and that didn’t work either. Any help would be greatly appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
While a pain you can use the keyboard arrow keys and the Control/Option keys to navigate via the keyboard. If the keyboard is responding via Bluetooth then the issue is a setting within the mouse Bluetooth settings. You might find it easier to plug in a USB mouse via a USB-C to USB-A adapter. Then open up the Bluetooth settings to re-establish the mouse's connection. Also make sure the mouse is charged.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hey Dan,
Thank you for such a quick response. I tried using the USB-C direct connect option, and as soon as I disconnected it, it came back to life. I REALLY appreciate your help.
Pete
por
@pete78265 - Happy to hear the direct wired connect reset things. If you're set don't forget to accept the answer - Thanks!
por
Adicionar a sua resposta
Pete será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 267
