Ir para o conteúdo principal
Guias de reparo, desmontagem e informações sobre resolução de problemas para a quinta geração do controle Sony PlayStation 5 DualSense. Identificado pelo número do modelo CFI-ZCT1W e pelo modelo da placa-mãe BDM-050.
Replacing haptic feedback rumble motors?
I've noticed recently after playing a lot of the f1 game, my haptic feedback is just suddenly extremely weak compared to what it used to be. I've tried pretty much everything I think and nothing works, tried enabling the speaker in my sound settings but my controller doesn't even appear in there. I downloaded dualsense x and tested the right side and left side rumble motors by themselves and the right side is significantly weaker. Wanted to know if replacing the rumble motors would be possible on the V5 since I don't already see any guides here and if so is it just the rumble motors that need to be replaced or anything also involving the triggers?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
The process is nearly the same as V2, V1 ect ect.
So you should be able to use the same guide that is created for the V2 or V1.
How is the haptic feedback? Still good? If yes, then you do not need to replace them, but just the rumble motor it self.
Guide: DualSense Controller v2 Vibration Motor Replacement - iFixit Repair Guide
If the haptic feedback buttons are back or got a lot weaker, then I advise to replace them as well.
Guide: DualSense Controller v2 Adaptive Trigger Replacement - iFixit Repair Guide
So far it does look like you just need to replace the rumble motors.
Please let us know if you have any questions!
Imagem de DualSense Controller v2 Gatilhos adaptáveis
Guia
Substituição do gatilho adaptável do controle DualSense v2
Nível de dificuldade:
Moderado
30 minutes - 1 hour
Imagem de DualSense Controller v2 Motores de vibração
Guia
Substituição do motor de vibração do controle DualSense v2
Difícil
1 - 2 hours
Esta resposta foi útil?
Pontuação 1
1 comentário:
Not muting your mic can override your haptics settings and set them to low or off make sure the button at the bottom is lit orange.
por
Adicionar a sua resposta
brending será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 45
Ao todo: 806
