Ir para o conteúdo principal
Guias de reparo para diferentes tipos de dispositivos de armazenamento, desde discos rígidos internos até unidades conectadas em rede.
How to remove heatsink Samsung 9100 SSD
I bought the Samsung 9100 Pro with heat spreader/heatsink (low profile) thinking it should fit, if not I could remove.
Samsung used what might be star screws because T5 Torx doesn't work and T6 is too large.
Can someone confirm type and size of the bit I need?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
@tumanwk we have to see what the screws look like. there are to many aftermarket suppliers and we do not know what this particluar one may have use. Adicionar imagens a uma pergunta já existente
The ones I have seen were P5 (Pentalobe) screws
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks for the quick response.
You guessed correctly it's pentalobe, I have to find where I miss placed my iFixIt Pro Tech Kit... Just verified the P2, P5, and P6 should be in my kit online. Now I just need to remember that wonderful location I moved it to, in order for it to be easier to find when needed.
My other kits are older and do not contain this bit style. I think unofficially when Apple started using these screws people referred to them as star bits .. but that didn't work, I figured best to ask the experts here.
Besides the training classes for Apple, (did phone technical support CPU/Computers) I haven't had to use Pentalobe screw bits/driver.
por
Adicionar a sua resposta
Tuman WK será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 111
Ao todo: 2,925
