Ir para o conteúdo principal
O Golf Mk5 foi introduzido na Europa no outono de 2003, chegando ao mercado do Reino Unido no início de 2004. Na América do Norte, a Volkswagen trouxe de volta o nome Rabbit quando introduziu o veículo em 2006.
Climatronic is not working
How to repair clima compressor
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Ac repairs are not DIY friendly due to most diyers unfamiliar with vehicle refrigeration repairs encompassing; tools and equipment needed for correct, safe, removal of refrigerant, determiing what parts need replacing, flushing the system of oil and contaminants if sealer was ever used, replacing oil, replacing old valve cores in both service valves, using new seals everywhere to ensure against leaks from a pressurized system whether operating or not, evacuating a repaired system, final leak test in a vacuum before refilling with new refrigerant. Diyers familiar with ac repairs will use refrigeration gauges to assess system refrigeration capacity in determining whether a leak or compressor damage occurred. As a rule, diyers are not equipped or skilled in repairing ac compressors other than replacing a blown clutch coil along wth new idler pulley and clutch plate. Compressors are replaced in its entirety.
If you are fortunate and a leak hasn't occurred requiring all the aforementioned items to make repairs, this may be as simple as a worn out compressor control valve operated electronically to govern compressor operation; https://www.youtube.com/watch?v=94dRjWG9...
Esta resposta foi útil?
Pontuação 0
1 comentário:
gas system is ok.
compressor is problem. i will replace control valve, and hope that it will work.
thank you wery much.
por
Adicionar a sua resposta
orban orban será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 184
