Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para o MacBook Air de 15 polegadas lançado em março de 2025, com chips M4.
Messages not working on Mac
When I get a code/ pin sent to my messages, it does not send until my phone has signal. Even though I have messages app on my Mac. Is this normal or not.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It can be!
There are a few issues here the first is your phone is likely connected to a cellular tower, and your laptop is connected to WiFi through your cellphone so the path is first through it!
if you have a cable/fiber internet connection it's possible your laptop is not setup to use the WiFi connection or the Router might not offer it so you need a USB-C to Ethernet dongle to connect to if via Ethernet.
Esta resposta foi útil?
Pontuação 0
5 comentários:
I am connected to wifi in a building, ie not connected to my phones wifi. i am connected to a router
por
@jellybeanman - Where did you submit the request? If you did it from your phone the phone number was hit first.
por
I uses a online thing to verify my identity and I put my phone number in, however my Mac has the messenger app
por
on my Mac, online a website
por
@jellybeanman - The phone number is used not your IP address which is also present but second.
That is normal!
por
Adicionar a sua resposta
Jelly Bean man será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 22
Ao todo: 287
