Ir para o conteúdo principal
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Perguntas Visualizar todos
Should I remove SSD in my situation?
Hi there.
I want replace my broken screen and first of all I should remove the display. So I stopped at this step: MacBook Air 11" Mid 2011 Display Assembly Replacement cause I have broken thread of screw. Its bad I know but I do not want replace SSD. So my question: Can I continue this guide without remove of SSD?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
It appears to me that you can continue with the guide without removing the card. Just be sure to observe ESD protocols when working on your machine, read through this before working on your machine: Electrostatic discharge (ESD) control
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks a lot. But I found problem with this: in next steps I should remove cooler but I can't do that without remove SSD, because screw hidden under SSD :)
por
Adicionar a sua resposta
Maxim será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 937
