Ir para o conteúdo principal
Informações de reparo e guias de desmontagem para máquinas de lavar roupas frontais da LG.
Help Finding Part For LG Washer
Hi! I need a door latch assembly for my LG washer model WM3470CM but I can't find the part that matches up to this model. Can anyone point me to one that will work so that I can replace it? Thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @wearingthepants,
Try using an EBF61315802 (supplier examples only)
Here's a video that shows how to replace it.
Update (09/17/25)
Hi @wearingthepants
The part number is usually found on the part itself if you wish to verify by checking the part number on the original door lock in the washer, that it is the correct one, before ordering it.
Here's an image that shows where to look
Imagem
(click on image)
Imagem de Keeps your washer door locked during wash and spin cycles.
Produto
EBF61315802 - LG Washing Machine Switch Assembly
$122.99
Esta resposta foi útil?
Pontuação 2
1 comentário:
Oh, thank you so much, this is very helpful!
por Compartilhar
Adicionar a sua resposta
Wearingthepants será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 234
