Ir para o conteúdo principal
A Olympus OM-1 foi lançada em 1972 como uma SLR de 35 mm revolucionária, oferecendo um sistema totalmente mecânico de nível profissional em um corpo significativamente menor e mais leve que o da concorrência. Ela apresentava um visor brilhante e controles exclusivos, como o seletor de velocidade do obturador localizado ao redor da baioneta da lente, em vez da placa superior.
Maintenance question for OM-1N
I picked up a near mint OM1n from ebay, and i really want to keep it in mint working condition but where i live (island nation) there are quite literally zero shops that specialize in vintage repair/maintenance cameras, let alone Olympus systems. And i dont feel like sending it overseas.
My question is basically this, is there any guide/video tutorial out there that shows and explains a complete CLA process for the OM1 or similar cameras? Im aware im no technician but i can follow specific instructions on my own risk, specifically what kind of lubricants/grease to use, when & on which parts, how to disassemble exactly whats needed and put everything back together. I tried youtube but it doesnt go much further than light seal replacements and prism foam cleaning.
Basically the most basic maintenance a professional would do to prolong the life of the camera.
Or at least as much as a regular person with normal precision tools can perform at home.
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You can find the repair manual for your camera online as a PDF from a few sources. Scan example here's the older version Olympus OM-1 service manual here's the rest of the manual grab the last one gets into lube OM-1 & OM-4 maunals
Esta resposta foi útil?
Pontuação 2
3 comentários:
now where is a copy for the OM2n ?
por
@om1gc - The mechanicals are the same across the OM-1 series. Only the metering and flash circuits are a bit different.
por
@om1gc see if the manuals on here Olympus OM-2 under the documents tab will work for you.
por
Adicionar a sua resposta
DBCooper será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 69
Ao todo: 830
