Why is it not turning on but only showing red lightning
Esta é uma boa pergunta?
@kadafimotingwa that lighting bolt means that your phone has a very low battery or is completely dead. The very first thing you want to do is to charge your phone, IF it does not charge then the issue could be a bad battery, a bad charging board or even a bad charger/cable. Check that first. Clean your charging port with a few puffs of compressed air. If that still does not work, replace the battery and re-evaluate.
Since iFixit does not yet have a specific guides for this, use something like this video Replacement batteries are readily available at many online stores.
If your phone has other issues then having to replace the battery, you need to be more specific with your question.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 59
Ao todo: 104
