What is causing a water under pressure error?
What needs to be fixed/replaced to solve this issue ? thanks
Esta é uma boa pergunta?
@slevinkele94271 your Keurig gives you that error when it can't force the hot water through the pods. Start by cleaning the opening of the top and bottom needle puncture valves. check this guide How to open and clean Keurig Coffee Maker for that . Also not the same model it's the same idea.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 29
